1989 Camaro RS Oil Problems
Old Oct 31, 2007 | 08:23 PM
Mercury's Avatar
Car: 1989 Camaro RS
Engine: 2.8L MPFI. Soon to be 3.4L
Transmission: T-5 WC
Hello,
I recently bought a '89 Camaro RS, with the 2.8L, off an insurance company. I was looking for a new project and the car still looked fairly nice and the only damage I could see was the small hit on the side. I have finally gotten around to running and driving the car, and lo and behold, like any other Camaro RS I have come across, some kid has beat the fire out of the car. I have already replaced a clutch that was worn down to the point of not being driveable, as well as a large number of other problems, and now I think the oil pump is going out on me. When I first got the car last summer I noticed the oil pressure was running fairly low, so dumped 30w50 Synthetic in the engine, hoping to increase the pressure. The oil pressure is getting low again, and I suspect the engine has had it. I know the bearings are probably going, but is there anything else other than the bearings or the pump that could be doing this? Finally, I really don't feel like rebuilding this engine, should it decide to go, so does anyone know what a decent 305 or another 2.8L should cost used?
Thanks in advance,
Robert
Old Oct 31, 2007 | 08:26 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: 1989 Camaro RS Oil Problems
you can get a 305 with some miles for about 500 bucks or so.
Old Oct 31, 2007 | 09:54 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Originally Posted by Mercury
Hello,
Thanks in advance,
Robert
How low is low? If it's above 5 psi at a warm idle it will likely be fine.
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
antares57
Aug 6, 2015 07:47 AM
