Using Sportsman II heads w/ centerbolt valve covers. Do I really have to grind perime
Old Nov 3, 2007 | 10:47 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have installed Sportsman IIs I just got back from the machine shop on my 327. I have been using centerbolt valve covers, and would like to continue using them. However, the Sportsman II installation instructions say I have to machine down the perimeter bolt bosses if I am to use centerbolt valve covers. I really do not want to do this -- has anyone run Sportsman heads w/ centerbolt valve covers, but not machined the perimeter bolt bosses down? I will go buy perimeter bolt valve covers if I really have to, but I really just want to use what I already have.
THanks!
STeve
Old Nov 3, 2007 | 01:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Using Sportsman II heads w/ centerbolt valve covers. Do I really have to grind pe
Yes you really have to do that, its in the instructions for a reason. If you dont, the valve cover will not seal and you will get oil all over the engine. We went thru that BEFORE it was in the directions.
Old Nov 4, 2007 | 12:31 AM
Car: 2000 BMW M5
After taking a look at the centerbolt valve covers, and the heads, it is now very obvious to me why they won't seal w/o grinding. In the trash go the centerbolt covers. I bought a new set of perimeter bolt covers. I like the center bolt design better, but I am sure as heck not grinding on these heads and ruining them for when I want to use larger dia. valve springs, and perimeter bolt covers must be used, later on.
Thanks for the answer, I appreciate it
Pac J
May 17, 2020 10:44 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
