Installing a Thumpr cam from Comp Cams
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I thinking about installing a Thumpr cam from Comp Cams in my 89 T/A - 305 HO and wondering if anyone can shed some light (what extra is needed or is it something that can be installed in a small block (305) without changing anything else??
Transmission: 4L80E/4L80E
Too much duration and not enough LSA to be computer friendly. Too much lift for stock heads.
Not a good idea.
Not a good idea.
Car: 89 T/A
Engine: LB9
Re: Installing a Thumpr cam from Comp Cams
Thanks five7kid any suggestions....I liked the sound bite on the Comp Cam web site that the Thumbr and MuthaThumpr cams made...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Wouldn't you rather have more power than more sound? Mufflers can get you nicer sound, the cam should be picked based on power!
The compxe258hr is a solid performer in the 305 TPI engine. Tried and true, a good replacement for your peanut cam.
Car: 89 Formula 350
Engine: 409 nitrous' small block
Agree, if you want a good sound, exhaust is a much better way to do it, hard to beat the sound of a flowmaster
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You'd be better off getting a cam that's actually meant to work well or a cam that's actually meant to give you tons of power, instead of sacrificing both for sound.
If you want a showcar, buy that cam and do what you need to make it work (heads, valvetrain, tuning), if you want a cam that's actually designed to work well, following Sonix' advice isnt a bad idea.
LT1Formula
Aug 20, 2015 09:36 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
