Plug Wires All Messed Up
Old Nov 7, 2007 | 05:40 PM
JeffD's Avatar
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
In the process of allowing a neighbor to help me with a plug/wire changeout the plug wires are now all mixed up as to where they go on the distributor. Is there a quick way to determine the #1 plug location on the distributor cap? I can get it from there I think...just have a mess right now.
Jeff
Old Nov 7, 2007 | 05:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remove distributor cap. Turn engine until timing mark lines up with timing tab. If the rotor is pointing mostly to the front, that's #1 (most likely). If it's pointing towards the back, that's #6 (most likely).
Old Nov 7, 2007 | 06:02 PM
Nsomnia's Avatar
Re: Plug Wires All Messed Up
and if you dont know where the timing marks are, turn it over till there is compression in the #1 cylinder
Old Nov 7, 2007 | 07:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
57's way sounds easiest to me, the way I remember is that on a large cap hei #1 is the second one clockwise from the 12volt/tach connection on the cap..
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
