car stalls at idle and hesitation
Old Nov 8, 2007 | 10:56 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I have an 89 IROC and it stalls when it idles and hesitates when you accelerate sometimes. Would a bad EGR be the cause of this? Can you clean them out or do you have to replace it? I already put plugs, wires, fuel filter, air filter, maf sensor, iac sensor, and injectors on it.
Old Nov 8, 2007 | 01:23 PM
sir'scamie's Avatar
Re: car stalls at idle and hesitation
yea i had the same problem....with my 89 rs
has yours ever cut off
Old Nov 8, 2007 | 08:23 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
have u checked the rotor button and check the coil and check for vaccum leaks. the egr valve u can check it by placing ur finger on the diaphram and see if it is opening and closing
Old Nov 8, 2007 | 08:43 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
it sorta sounds like a vacuum leak but i replaced some of the cracked hoses but still didnt do anything, the dist is fine, spark is fine. EGR is the only thing i can think of, unless its a clogged cat.
Old Nov 11, 2007 | 06:18 AM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
You can take the egr off and clean it with some carb cleaner. You can also check the egr solenoid make sure it is working. I would try using some seafoam I would use it through the brake booster line and pvc line. Also have you check the tps?
Old Nov 11, 2007 | 09:08 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I couldnt get the damn egr off, i dont know if it is the problem now though cos it runs the same with it off and the vac line plugged. No check engine light either, i think it might be a bad ecm maybe? Im gonna check the tps today.
Old Nov 11, 2007 | 07:45 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Could a pvc valve cause rough idle/hesitation? I checked the tps, i think its fine but im gonna pull one from a boneyard i think to make sure. I cleaned out the throttle body also and the problem still remains...
Old Mar 30, 2012 | 01:28 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Ever find out the problem?
Old Mar 30, 2012 | 02:14 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Throttle body cleaner from oreilly's is like 5 bucks, it worked for my car. I had a similar issue that I would have to keep my foot in it to keep it running and it wouldn't idle for the life of me.
Old Apr 5, 2012 | 02:27 AM
91'CamRS's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 v8 TBI
Axle/Gears: Stock
Get the codes! Im having a same problem like this and just started throwing parts at it (huge list lol) got the codes and now i know where to go to next! Its easy and only takes a paperclip and a few minutes. Search how to do it in the threads.
Old Apr 5, 2012 | 02:30 AM
91'CamRS's Avatar
Engine: 305 v8 TBI
Axle/Gears: Stock
Also a clogged cat would make it seem like theres a loss of power and its not shifting at all. You could floor it and barely get up to speed! My cat was clogged and i had to gut the thing. This doesnt sound like this is your problem..
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
killer777
Aug 8, 2015 02:47 PM
