Oil leak?
Old Nov 10, 2007 | 06:36 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Oil leak?
After going to the track last night for the first time i came home and found that there was some oil splatter near the snorkles from my air filter housing and around the intake bolts . Well it seems that my Patriot perf. heads have 2 holes on each side next to the intake mounting bolts that since they aren't plugged by a screw or anything were squirting out oil through the thrreaded holes and as the car was running hard the oily stuff was being sucked in somewaht by the air cleaner snorkles. Anyone heard of this ? I'm going to simply plug the holes with screws with sealant on them to stop this but it seems weird. Could these holes be for a vortech style intake and as such should be plugged?
Old Nov 10, 2007 | 06:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil leak?
Vortechs use an entirely different bolt pattern. Where are these holes, exactly?
Old Nov 10, 2007 | 07:38 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Oil leak?
Old Nov 10, 2007 | 08:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The picture is good, but knowing exactly what heads they are would still help.
They look like Vortec-style heads with both patterns drilled & tapped. Typically it's better to use a Vortec-specific intake on that type of head.
Old Nov 10, 2007 | 09:36 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Oil leak?
as listed in my signature they are Patriot Performance heads from White Perf. and yes they are drilled for both styles. I already had a perf.rpm intake when i got the heads and just re-used it.
Old Nov 10, 2007 | 11:11 PM
five7kid's Avatar
Does Patriot Performance only make one head?
Old Nov 11, 2007 | 01:21 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Oil leak?
NO several actually but i guess the closest would be these links
http://www.patriot-performance.com/w...03567&DID=1225
and
http://cgi.ebay.com/ebaymotors/PATRI...spagenameZWDVW
the ones from ebay are the exact ones i got . I just didn't know you had to plug up the unused hole and ended up having to simply screw in intake bolts into them with sealant to be sure they dont leak
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
