ran out of gas...
Old Nov 16, 2007 | 12:59 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
ran out of gas...
now it wont start or idle unless i gas it... fuel pump is priming any ideas?
Old Nov 16, 2007 | 01:43 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Re: ran out of gas...
It sounds like all the sediment and crap that used to be in the bottom of your gas tank is now in your fuel filter. Check that out first, it might be a cheap fix!
Old Nov 16, 2007 | 06:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Running it out of gas is very hard on electric fuel pumps, because they use the fuel in the tank for cooling. No fuel (none being less than 1/8 tank) means no cooling. Its very easy to fry a pump that way. Check your fuel pressure, and make sure its adequate. Should be at or above 40psi for a TPI car, or at/above 10psi for a TBI car.
Change your fuel filter too. Picking up all the junk at the bottom of the tank causing the problems isn't anywhere near as common as people think, but its cheap and its probably due anyway if it hasn't been done recently.
Old Nov 16, 2007 | 06:37 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yeah, the fuel actually passes through the inside the motor and around the rotor to cool it as well as lubricate the bushings. If the pickup is exposed and you try to start the car multiple times, it can damage the pump.
Old Nov 17, 2007 | 02:30 AM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
it already has a brand new filter maybe has had half a tank run through it... could it not be giving enough pressure even though its still priming? looks like i might have to rob my parts car of its pump
Old Nov 17, 2007 | 03:08 AM
xChAoSx's Avatar
Car: 1987 Firebird
It not pump gas. That sucks because its located in the gas tank. Your going to have to drop the whole rear to get to it. Thank gm for that one
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Linson
Oct 1, 2015 09:50 PM
