350/305 Crankshaft compatability ?
Old Nov 17, 2007 | 11:53 AM
Allchevyman's Avatar
Car: 87 chevy C/K pkp
Engine: 305 TBI
Hello All:
I am rebuilding a stock 305 (1987)TBI engine.The crankshaft needs work.I also have a (1996) L31 350 crank and rods in great shape.
My Question :
Can I use the good 350 crank and rods in my 305 block if I use the vibration damper that comes off the 305 crankshaft.
Will the rotating assembly be balanced ? I plan to go back with standard size pistons.
Thanks for your help.
Old Nov 17, 2007 | 12:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 350/305 Crankshaft compatability ?
The balance weights on the crank will be different so you'll need to get the rotating assembly balanced. The 350's crank will be balanced for the larger, heavier 350 pistons. They're both neutrally balanced but the reciprocating weight is different.
Any engine where you mix and match parts needs to be balanced. Even using aftermarket pistons and rods will need balancing because they don't weigh the same.
Old Nov 17, 2007 | 06:33 PM
Engine: 305 TBI
Stephen,
Thanks for your prompt, informative reply.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
LT1Formula
Aug 20, 2015 09:36 PM
