code 44, surging idle
Old Nov 17, 2007 | 02:36 PM
jordeezy's Avatar
Car: 1985 Trans Am
Engine: 305 LG4 boat anchor
Axle/Gears: 3.27 "Down Under" 9-Bolt
I have an 85 TA 305 LG4, and I am getting a code 44.
The car warms up fine - fast idles at 1800, then drops to 700, and will stay that way for several minutes. Then, the SES light comes on and the idle starts surging between 1500-2000rpm. I checked for codes, and I got a 44 (o2 sensor lean)
I replaced my O2 sensor, and I can't seem to find a vacuum leak, but still get a code 44 and the surging idle. Not to mention fuel economy has been pretty bad. Any ideas? Thanks in advance.
Old Nov 18, 2007 | 07:33 PM
jordeezy's Avatar
Car: 1985 Trans Am
Re: code 44, surging idle
anyone?
Old Nov 19, 2007 | 08:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What is the setup? What changes/modifications have you done? Does the surge happen only under certain conditions? What engine temp does it start doing this at? last tune up?
Old Nov 19, 2007 | 11:13 PM
jordeezy's Avatar
Car: 1985 Trans Am
-all stock
-installed rebuilt e4me carb last summer
-last tune up was last summer too
-new plugs, wires, dist cap & rotor, filters
-new o2 sensor, pcv valve
The problem happens every time i start the car. The idle stays at 1500-2000rpm after the ses light goes on (which stays lit for a minute then goes off). Not sure what temp it starts at, I can find out though.
Old Nov 26, 2007 | 12:18 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
sounds like an EGR problem...a tiny piece of carbon could get stuck in it and it would be slightly open..causing a lean condition. You need to remove it and clean it up...but first run the engine and hold it at 2000-3000rpm and use a squirt bottle to spray water into the manifold. The water vaporizes and will help to cleanout the carbon in the cylinders, most will go out the exhaust..but some will end up in the EGR valve.
Old Nov 28, 2007 | 01:03 PM
jordeezy's Avatar
Car: 1985 Trans Am
RodsRide, I replaced my EGR valve recently, and ran Seafoam through the engine, but I will try cleaning out that manifold. Which other EGR components should I check? Thanks
Old Nov 29, 2007 | 08:22 PM
Air_Adam's Avatar
Have you found a definition for what Code 44 is yet?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
