New owner questions
Old Nov 19, 2007 | 01:48 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
New owner questions
I have a new 82 Camaro CFI (save it, I am building a 383 for it) that I just bought and am trying to fix a few issues. First the car smokes mostly on statup but a little after warm up also. Mostly I am concerned because the smoke smells real strong. Like normal exhaust just stronger ( best I can explain it. It will give you a headache standing next to the car for a few minutes). Also the car ideals real fast on start up (like 1800 sometimes) for a few minutes then slowly goes down to about 100. And here is my second problem. When the idle comes down after warm up it gets rough. Like its trying to get down to the 500 mark but then shoots back to 1000 for a few seconds then repeats it. Last problem is a ticking sound under the passenger foot area (close as I can tell). It sounds like a exhaust leak and I found a loose bolt on the manifold but it did not fix it.
Oh by the way the guy gave me a recipt for haveing the motor rebuilt about 20,000 ago. This guy gave me a hole 4 inch thick file of reciepts dating back to 1982.
Any help would be great.
Old Nov 19, 2007 | 09:08 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: New owner questions
What color is the smoke when you first start the car?
Old Nov 20, 2007 | 02:28 AM
sweetaq's Avatar
Car: 1982 Z28
Brownish I would say.
Old Nov 20, 2007 | 07:41 AM
When the guy did his rebuild, did he have the valve-guide seals replaced?
If the smoke is dark and on startup, in my experience it is typically valve-guide seals that are worn-out.
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
chazman
Aug 22, 2015 02:01 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
