Fuel Feed/Return Lines
Old Nov 21, 2007 | 11:54 AM
cjames9001's Avatar
Car: 1986 Trans Am WS6 Pkg.
Hi I have an '86 Firebird Trans Am and I'm working on getting the Fuel Rail taken off so I can replace O-rings and whatnot on the fuel injectors but im having trouble removing the fuel feed line it seems that the nut has warped and on top of that I think its rusted a bit making it really difficult to remove, I've tried getting the standard 5/8 flare wrench on there but its warped enough that that will not fit, on certain sides I can get a 20mm open ended wrench to fit perfectly and on some sides I can get the 5/8 open ended wrench to fit... if anyone has any suggestions or has had this problem before help would be much appreciated, thanks in advanced!
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
