oil circulation question
Old Nov 22, 2007 | 12:45 AM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
ive got an 89 350 tpi and i just replaced the headgaskets and noticed when i started it up with the valve covers off to adjust the valve lash i noticed that the was alot of oil would be coming out of some of the rocker arms and vertually none coming out of two of them.
i put sealant on the head bolts and i just want to know if the sealant i put on could have clogged the oil passages or that some parts get of the motor gets more oil than others.
if it is clogged. if, what would i do to unclog it?
thanks in advance.
Old Nov 22, 2007 | 01:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil circulation question
I wouldn't be too worried about it unless there was no oil at all coming up. There are no oil passages through the deck.
Old Nov 22, 2007 | 01:18 AM
86Pontiac's Avatar
more than likely either some of the lifters aren't fully pumped or they are dead
Old Nov 26, 2007 | 04:08 AM
how would i go about pumping the lifters and is there anyway i can test them to be sure if they're dead or not or is my symptom the tip off?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
