pistons
Old Nov 22, 2007 | 11:16 AM
americanmuscle3's Avatar
Car: 83 z28
pistons
im rebuilding my 350 and i have a question about pistons. i have looked at all sorts of brands for pistons and was wondering i was looking to run around 10-10.5:1 compression n/a this year and possibly put nitrous or another power adder in the future i really dont want to have to tear the whole motor down again at that point what is a good forged piston that is reasonably priced that could handle a power adder in the future? Thanks
Old Nov 22, 2007 | 11:26 AM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Re: pistons
Those Mahle Motorsports pistons are about as good as youll get as far as price and quality. The power pack pistons even come with rings. Also SRP or Sealed Power are reasonably priced as well.
Seth
Old Nov 22, 2007 | 03:06 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: pistons
americanmuscle3,
Keep in mind that if you do use a power adder you should lower your comp relative to the amount of nos/boost/psi that you will be using. Then it is definitely imperative to use forged pistons.
As for the brand of pistons, I have used a set of trw's and je pistons and they both did great. Now for the money trw or, like seth was saying, sealed power is also a great alternative.
Rabi C.
Old Nov 23, 2007 | 10:34 PM
Car: 83 z28
Re: pistons
i had looked at trw and sealed power and because of the lower price i figured the quality wasnt there
Old Nov 24, 2007 | 07:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: pistons
The reason they're cheaper is due to higher volume. TRW/Sealed power make pistons for the OEM, so they produce massive quantities. Also, everyone buys them in the aftermarket, which means they make a ton for those applications as well. That helps them keep them cheaper.
The brands that don't make as many, or make custom sizes are more expensive due to the extra tooling involved, and the price of putting a nice shiny name on it. TRW pistons don't come with a high performance sticker
Old Nov 25, 2007 | 12:07 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: pistons
I've used TRW, Keith Black, and SRP. Haven't had any problems with any of the three.
Old Nov 25, 2007 | 12:57 PM
BadSS's Avatar
Re: pistons
The 2618 allow pistons are what I look for when I'm building an engine I plan on spraying. The Keith Black budget forged pistons are 2618 alloy and a good value at $293.
http://www.cnc-motorsports.com/produ...08&CtgID=18728
Their premium series is a VERY nice 2618 piston also and is lighter with a smaller ring package. At $376, it would depend on your end purpose whether or not they'de be worth the difference.
http://www.cnc-motorsports.com/produ...81&CtgID=12779
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
