Crate Motor Guys - What do you do about your drain plug for oil changes?
Old Nov 23, 2007 | 11:53 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
GM crate motors come with a special drain plug that has a rubber seal built into the flange of the bolt. This rubber wears out after each use so I have to buy a whole new drain plug every time I change my oil. The plug is like 5 bucks. What am I missing?
Old Nov 23, 2007 | 11:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Crate Motor Guys - What do you do about your drain plug for oil changes?
Don't torque it down so hard and it'll last forever.
Old Nov 23, 2007 | 12:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
?? My stock oil pan plug has that rubber seal, and it lasts forever... You torque it down lightly and it's great.
Old Apr 19, 2008 | 06:07 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Still isn't working. I tightened it only light enough to make a seal, and it worked great the first go-around. Changed my oil, and when I go to re-use it, theres a drip forming within minutes.
Old Apr 19, 2008 | 06:30 PM
ljnowell's Avatar
You can buy in bulk oil plug washers. The dealerships refer to them as gaskets. You could probably go the the dealer or someone such as them and get some reasonably cheap. I probably have about twenty in my toolbox that i put on the long grained variety of auto.
Old Apr 19, 2008 | 07:24 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
autozone sells the washers seperatly for like 46 cents
Old Apr 19, 2008 | 07:34 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Any part numbers?
Old Apr 19, 2008 | 08:17 PM
bryan89's Avatar
Car: 88 Firebird
Engine: 305 TBI
I got a new plug for $1.48.
Old Apr 19, 2008 | 08:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you could always just not change your oil....
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Navy8125
Aug 21, 2015 09:32 AM
Street Lethal
Aug 14, 2015 08:25 PM
