this is a weird one bent dipstick hole. need help
Old Apr 18, 2008 | 12:32 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
i just pick up this GTA and when i got home i saw it has no dipstick. so I took the dipstick from my formula and tryed to put it in the gta but it got jamed and would not go down all the way. I looked at the dipstick hole and its bent up pritty bad. how do i change it out and put a new one in. I have no idea how low the oil is and i need to get this done fast.
Old Apr 18, 2008 | 02:39 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: this is a weird one bent dipstick hole. need help
I'm not sure how clear of a view you have, but it may be the remains of a broken dipstick causing problems. It might be good to check for.... if not, then it's a new one to me. I've never seen a block get bent there.
Old Apr 18, 2008 | 03:50 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I think he means the dipstick tube is bent. It's just pressed into a hole in the block (there might be a tab on it bolted to something also, can't remember), but getting it out (and a new one in) probably won't be a lot of fun with the engine in the car. Try grabbing it with a pair of vise grips, as close to the block as possible to avoid breaking it, and slowly turning it back and forth, and pulling up at the same time. Once it's out, find a new one, put a little oil on the part that slides into the block, and slowly tap it in with a small hammer.
Old Apr 18, 2008 | 08:07 PM
Car: 91 formula
i mean its the dipstick tube. sorry. I am going to change the oil because i can't see how bad it is i just bought this car.
Old Apr 19, 2008 | 08:52 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
If it's anything like the one on my '87 IROC, there's a reason the previous owner didn't fix it. I did get mine in, but it sure wasn't a fun time.
codeysabatini
Nov 10, 2015 04:07 PM
NZKnight
Oct 15, 2015 02:47 PM
Zell1luk
Sep 29, 2015 10:36 AM
KCG
Sep 23, 2015 09:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
