power steering pump Q.....
Old Nov 24, 2007 | 07:41 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
does anyone know if there was a pressure output difference between our third gen saginaw pumps and the older tower reservoir pumps found on 70's chevy's? i have the older pump and want to know if I could use it in my 3rd gen....long WP; v-belt pulley. thanks
Old Nov 24, 2007 | 08:43 AM
Damon's Avatar
Re: power steering pump Q.....
They run at the same types of pressures becuase steering box technology hasn't changes in a zillion years. But the fittings will be different on the older pump- you can't screw your stock lines into it.
Old Nov 24, 2007 | 09:09 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The older pumps run a lower pressure because the ratios back then were a lot lower (like 4:1 vs 2:1 now). It will still work, but the pump will complain at low speeds. I have an IROC box in my '68 with the original pump. You'll need different hoses or adapters to hook it up.
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
