Is My Starter Dying
Old Nov 25, 2007 | 10:27 AM
mattheat's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 Non Computer Edlebrok Carb
Transmission: Turbo 350
Axle/Gears: Original ones that came with car
Is My Starter Dying
I Was trying to start my camaro yesterday all it would do is click, i though thAT it might be the battery so i charged it, but it does the same thing, could the starter be to weak to turn the engine? i have a 85 Cadillac sitting next to my camaro, could i use the starter from it? my camaro has a 305, the cad is a 4.1 v8 fwd if there not the same could i just swap the insides of them out?
thanks for any suggestions
Old Nov 25, 2007 | 12:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Is My Starter Dying
Probably going out.
Can't help you on the caddy though.
Check the part numbers online and see if they're identical. That may help you.
Old Nov 25, 2007 | 06:21 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
have made sure your wires connected good to your starter
Old Nov 25, 2007 | 07:00 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Matt,
Roy is right check everything out first before you throw parts at the car. Starting circuit is fairly simple. Large positive battery cable goes to big lug on the starter solenoid & small wire from ignition circuit goes to the S terminal (several fusible links in there on the big lug). Ignition power pulls in the coil on the solenoid, throws out the Bendix drive and powers the starter motor to turn over the engine.
Your is clicking, so find out why the starter motor isn't turning over. Bad solenoid, bad starter motor, engine locked up or starter gear jamming against the flywheel. You can crawl under car (please use jack stands & make sure the car is in park or neutral with the e-brake on) and use a small FUSED jumper wire to go from the big lug on solenoid to the S terminal & see if the starter turns the engine over. Or you can pull the starter & do all your testing on the bench. When the starter is out you can take the time to freshen it up, or just replace it. But satisfy your curiosity by doing some troubleshooting first.
Corky
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
