buying a 84 camaro
buying a 84 camaro
getting an amazing deal, only a few problems with the car, its an 84 camaro:
1. passanger side window dosnt go down
2. small oil leak, the guy says where the dipstick goes into the motor, the rubber ***** off, is this common, or can it be somthing else
3. there is a leak in the firewall, and it leaks onto the floor, looks like im going to have to pop the dash out and fix it,
just wondering if these are common problems with the older 3rd gen camaro's and if it isnt to hard to fix these problems, thank you for reading!
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: buying a 84 camaro
Just my 2 cents.
Hope this helps!
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
I thought my dipstick was leaking,, turns out the valve cover gasket on that side was leaking. hope it helps
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Transmission: 4L80E/4L80E
The leak onto the floor, if on the passenger side, most likely is the heater core.
Engine: 5.7L/350
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
