Can 83 305 be changed to roller cam?
Old Nov 27, 2007 | 03:38 PM
Strick 92's Avatar
I just thought I'd ask as we're going to explore the inside of our 83 305 LG4.
Old Nov 27, 2007 | 03:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Can 83 305 be changed to roller cam?
Yep. Retrofit roller conversion, ~$700. Is it worth it for your 305?
Old Nov 27, 2007 | 03:46 PM
Strick 92's Avatar
And that's not counting the cam? How about lifters? What is in the kit? BTW, Thanks
Old Nov 27, 2007 | 04:53 PM
No "kit".
You need a cam, a set of lifters, and a cam button. A better timing cover than stock also isn't a bad idea.
Old Nov 27, 2007 | 05:14 PM
Strick 92's Avatar
No "kit".
I'll ask, what's a cam button?
Old Nov 27, 2007 | 05:17 PM
http://www.compcams.com/technical/Ca...106-07/324.pdf
I usually use the 200
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
