cylinder head dyno test results
Old Nov 27, 2007 | 04:31 PM
grumpyvette's Avatar
http://www.boatstoreonline.com/procomp.html
Old Nov 27, 2007 | 05:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: cylinder head dyno test results
Interesting. Thanks for the heads up.
Old Nov 27, 2007 | 07:06 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Thanks grumpy.
-Schultzy
Old Nov 27, 2007 | 07:52 PM
TUNGSTEN's Avatar
Engine: 355
Axle/Gears: 3.73 Trutrac
Very interesting.
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You get what you pay for when it comes to heads.
Old Nov 27, 2007 | 08:52 PM
Damon's Avatar
Ouch.
I'm surprised they didn't inspect the heads PRIOR to running them and having problems- especially since the problems were apparently obvious by eye. I know that if I'm laing down 4 figures on heads I inspect them out the wazoo before bolting them onto the motor. Chamber sizes, valve seats, valves, springs, guides, etc. I fully disassemble the head and measure everything prior to using it. I have to admit I've never cc'ed the intake ports on my heads but I will after reading this article!
You'd be surprised what you find on even good quality heads. I'll mention in passing that AFR's spring specs are out to lunch, in my opinon (usually higher pressures than advertised and by a fair bit). Had several sets now- springs never match the specs, although their installed height is usually *****-on spec. Plus they use crappy quality seals, although I will admit I've not had a problem becuase of it.
LT1Formula
20
Nov 14, 2015 12:02 AM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
