SPARK PLUG HELP!!!
Old Dec 1, 2007 | 12:17 AM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
SPARK PLUG HELP!!!
yea so some friend of mine was trying to replace his spark plugs. When he was trying to take them out, the plug broke and half of it is still in. What can he do to get it out? i told him i knew a good website that i get a lot of help from.
THANKS GUYS AND GALS!
-Andrew
Old Dec 1, 2007 | 12:24 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: SPARK PLUG HELP!!!
'brn91
Unless the metal part of the body broke then put your socket back on again and back it out. In the past I broke insulator portion off, but as long as hex flange part is ok it can be taken out rather easily
//RF
Old Dec 1, 2007 | 02:22 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
it should be fine, just put the spark plug socket on as usual and just undo it, if you can get a clear look at it instead of doing it blind that would be better
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
