I would like opinions...
Old Dec 3, 2007 | 12:25 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I am building a 350. It's .030 over with flat tops, a 282/282 duration 465/465 lift cam, and 461 double hump heads. What kind of power you guys think i'll make?
Old Dec 3, 2007 | 07:29 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: I would like opinions...
No one can tell you how much power since you didn't tell us the year/make of the car, if its TPI/carb/TB, tranny specs, rear end specs, etc.
Lose the double hump heads and go with an aftermarket set - you will make more HP.
Old Dec 3, 2007 | 07:33 AM
And don't forget of course, those heads won't fit these cars (no accessory bolt holes); so they need to go away, no matter what. Doesn't matter how much power it makes if you can't install it.
Old Dec 3, 2007 | 07:54 AM
Excellent point!!! I forgot about the bolt holes
Old Dec 3, 2007 | 08:46 AM
82Five-O's Avatar
Car: 82 Sport coupe
it's a carbed 350 with a 700r4 tranny and 2.42 gears in the rear. 82 camaro. the bolt holes dont matter because i'm only running an alternator and a power steering pump neither of which are going to mount off the head because of the brackets i have. it doesn't matter because these have the holes machined into them. You know some 461's did come with holes just like these.
Old Dec 3, 2007 | 02:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which cam exactly? Part number?
What pistons are in there? Part number?
Was the block decked? Piston height?
Intake system? Carb model? Intake model?
Without that info it could make between 220HP and 420HP, depending on those parts, and how you're measuring the HP.
WhteRbt
Sep 10, 2014 07:37 PM
utfan01ss
Wheels and Tires
Sep 2, 2014 02:42 AM
luvofjah
Jan 1, 2014 04:40 PM
mw87bird
Jun 5, 2009 11:00 PM
BAK12484
Apr 7, 2002 05:59 AM
