distributor removal 90 V6 3.1 L EFI
Old Dec 6, 2007 | 08:56 PM
whatdayasay's Avatar
i think my distributor o-ring needs to be replaced due to oil leakage. I plan on removing the cap and marking the location of the rotor button and distributor at the engine and pulling the distributor out and replacing the o-ring and reinstalling everything like it was. a few questions
1. should i set the engine to TDC before i start?
2. will i need a special wrench to remove the hold down bolt?
3. should i put in a new or rebuilt distributor while i have it out or just put the old one back in?
4. will i need to set the timing after this work is done?
5. do i have to remove the hood to get the distributor out?
6. any suggestions or tips or what to watch out for would be appreciated.
thanks,
whatdayasay
Old Dec 6, 2007 | 09:17 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: distributor removal 90 V6 3.1 L EFI
take note of where your rotor is pointing when you remove the distributor. DON'T Turn it. You can remove the hold down bolt and tab with a 9/16 box end wrench, You can drop a new dizzy if you want, but that's up to you. It's possible to get the dizzy out with the hood on, but, everything is easier with it off of course.
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
PimpRod92RS
Jan 24, 2003 12:05 PM
palric
Jun 26, 2002 11:26 PM
SAEspinz80
Aug 5, 2001 10:04 PM
