Balancer and flexplate for ZZ4
Old Dec 6, 2007 | 10:42 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I just bought a new zz4 shortblock with 1 piece rear main seal.
I now learn that this motor is externally balanced. I realize that I need the proper flexplate.
Will a fluid damper from a pre 86 350 work?
The damper that gm lists for the zz4 is the same as used in z/28s and L82 and LT1 engines. This leads me to believe that I can reuse my balance that was on an internally balanced engine.
Please comment.
Old Dec 6, 2007 | 10:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Please, let's not start this again.
One-piece rear main seal flexplates/flywheels have a weight. This weight takes the place of a built-in weight on two-piece rear main seal cranks. This does not make one-piece rear main cranks "externally balanced", it makes them "one-piece rear main seal".
Just get a flexplate for one-piece rear main seal crank applications.
The harmonic damper is neutral balanced, just like every factory SBC damper except 400's.
Old Dec 6, 2007 | 11:00 PM
SDIF's Avatar
Re: Balancer and flexplate for ZZ4
Thanks 57kid!
That the answer I was looking for!
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
roysatikas
Sep 7, 2015 08:08 PM
