Can a really low idle..
Old Dec 7, 2007 | 02:10 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Do any damage to the engine. Right now my car once it warms up enough will idle very low. Somewhere between 350-450rpms. It almost dies on me but it wont. I been trying to figur out the problem. But no use. I have also realized that my torque converter is shot. And when the torqu converter acts up, so does my horrible idle. Any relationship between the two?
Old Dec 7, 2007 | 01:54 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: Can a really low idle..
test you tcc solenoid and circuit
Old Dec 7, 2007 | 01:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TCC doesn't get any hydraulic pressure in 1st gear or neutral/park, so it's not likely that's the problem.
A TC with a problem could very well be the problem. The biggest issue about that isn't the engine, it's what you may be circulating around in your transmission because of the bad TC.
Old Dec 7, 2007 | 08:56 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Alright, but let me get this straight. The low idle could be because of the tc? or you said no it isnt.
Old Dec 7, 2007 | 10:00 PM
five7kid's Avatar
I said it couldn't be because of the TCC lock-up solenoid or circuit.
It could be because of a bad torque converter.
Old Dec 7, 2007 | 10:11 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Thanks alot five. I have been going absolutely nuts trying to fix my tps, IAC, ignition and everything. Trying to figure out what may be going on. Now I'm not gonna waste time and see what a new TC will do. At least it will help my lockup probblem
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
