oil pressure gauge question
Old Dec 9, 2007 | 12:23 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
with just the ignition on not the engine on
im readin 13psi on the oil gauge.
is the ok or is my digital dash screwing up?
it get around 53 when idling i believe.
Old Dec 9, 2007 | 12:34 PM
Re: oil pressure gauge question
Disconnect the wire from the sending unit, and short it to ground with an alligator clip lead. Should read zero.
If it does, the gauge is OK; and you need a new sending unit.
If it reads 13 psi, your gauge is farkled.
53 psi at idle, hot, is not right. You DEFINITELY have a gauge system issue of some sort.
I'd be expecting that it's the sending unit.
Old Dec 9, 2007 | 03:04 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok what shoudl my readings be with just ignition on and at idle?
Old Dec 9, 2007 | 03:23 PM
Ignition on not running, 0.
Hot idling, maybe 20-30 psi.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
R3500
Aug 17, 2015 12:16 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
