oil pressure help
Old Dec 9, 2007 | 07:35 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
oil pressure help
what should be my oil pressure be?
with just the igniton on?
then at fully warmed up engine at idle?
Old Dec 10, 2007 | 02:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With just the ignition on and engine not running? Zero.
Engine warmed up and idling, 10 psi is sufficient, 15-20 isn't uncommon.
Old Dec 10, 2007 | 08:33 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: oil pressure help
warm and idling:
'88 IROC TPI 6.4L L98 and '99 S-10 4.3L V6 both 40psi.
Old Dec 10, 2007 | 08:42 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
wow..my warm idle (in all cars i've seen) seems to be able 10-15psi per 1k rpms...course my car went to 60psi by 3k
Old Dec 10, 2007 | 10:40 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes, that's a standard.
The oil pump in the IROC is a HV, but the spring presssure is reduced. I use a manual gauge located near the engine.
Don't know why my S-10 is just as high, but I don't think it's a problem.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
