removing oil sender and temp sender any tips?
Old Dec 10, 2007 | 08:56 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im about to tackle removing the temp sender and oil pressure sender for my gauges
any tips like warming up the car? to make the senders unscrew easier since they have been in there for 20yrs?
my fear is ill get hit with hot coolent or hot oil if i do that
also any kind of teflon or a any kind of lubricant to put on the new sender threads?
Old Dec 10, 2007 | 09:07 PM
Re: removing oil sender and temp sender any tips?
I wouldn't do it with the motor hot.
Rotate counterclockwise.
Installation is the reverse of removal.
It'd be a good idea to drain the cooling system before doing the temp gauge one.
The oil one, there's no real prep for; just change it out.
Use automotive-specific pipe thread sealer, such as the Loctite/Permatex kind that comes in a little tube on a card in the sealer aisle at the parts stores.
Old Dec 11, 2007 | 12:46 PM
Bobby_80s's Avatar
Axle/Gears: no idea
use that stuff on both coolent and oil sender threads?
Old Dec 11, 2007 | 12:50 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
if it looks rusty, spray some WD40 in there over night. Start by tightening, just a tad, and then unscrewing.
It wont break like a bolt, so u dont need to take those precautions really, just use a proper wrench and dont strip it.
NBrehm
Aug 25, 2015 11:49 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
3rdgenparts
Aug 8, 2015 07:09 PM
