383.. NEED HELP!!!! BADLY!!!
Old Dec 15, 2007 | 05:06 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Ok I have a 350 block bored out .30 over and I just bought a fully forged rotating assembly(with H-beam rods and flattop pistions) deeper oil pan and alot of other things for this motor. I am about to just give up on it because nobody that I bring the motor to can get this thing assembled for me(like clearance it if nessarary and make sure nothing will blow up on me this time) in two weeks. I thought it would be easy for a shop to just put like a couple of days into just throwing this thing together and check things along the way but I guess it takes 4 months + some to even put a finger on it. Or would I be better of just trying to throw it together with my dad. Which was actually done by the first machine shop that I paid before the motor blew. But I had I-beam rods then do you guys think there will be much of a difference in the clearancing to where I need someone else to do it? Or can I do it and get away with not paying any more jackA**es.
Old Dec 15, 2007 | 07:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Got a die grinder and some patience? Go ahead and clearance it yourself.
I kinda doubt that. 0.030" over, maybe. Or I could buy 30 over (as in 30 mils). But, no 350 block is going to handle a .30" overbore.
Old Dec 15, 2007 | 09:03 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: 383.. NEED HELP!!!! BADLY!!!
First me and now this poor guy who forgot his zero...LOL!
What do you need to clearence? The cylinder skirts? If thats all I would say a die grinder and a carbide burr bit and do it yourself.
Old Dec 15, 2007 | 09:05 PM
supercharged383's Avatar
Car: 88 Camaro
Engine: Supercharged 383 stroker
Axle/Gears: Auburn posi motive 4:10 Moser axles
Itook mine to the local machine shop here and they did all machine work clearanced it and put together the rotating assembly and did a good job i would find another machine shop
Old Dec 15, 2007 | 10:28 PM
five7kid's Avatar
Just don't want anybody to do a search some day and say, "See, you CAN bore a 350 .30" over!"
Mostly the pan rail on the block. Sometimes the rod bolt (you need to have the cam and timing set installed when you do this).
Old Dec 16, 2007 | 08:27 AM
1BadaGTA's Avatar
Yeah the .30 was a type error. Because I am just really pissed of that I spent $1200 the first time on all the block work alone and the freaking thing blows up on me and then this other machine shop told me he could have it done within two weeks and here I am at two weeks and the idiot hasn't even touched it. Not to mention that I have somewhere around $5000 in the parts I left with him. I think anyone else would be just as pissed as me if this were happening to them. So if it just needs alittle clearancing then I guess I'm going tomarrow to pay a surprise vist and get my money and parts back. thanks for the info guys.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
