help with tv cable adjustment
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
this is for the people having problems like "my car is sluggish in acceleration" or "if i try to increase my speed, it sounds like my car is in neutral and i am going nowhere"
(but this is not saying this will fix your problem, it just helps)
or simply for the people who havent done it in a while.
IF you have a 700r4 or if you car has a TV cable adjuster on it, just press the "D" button and push the back side of the cable into the housing(it is kinda hard if it hasnt been done in a long time, but you should hear it click or "ratchet") push it all the way in, then manually open the throttle all the way, (you can do this 3 or 4 times) and there ya go, your TV cable is now adjusted.....or maybe not READ BELOW!!!!!
*EDIT* this was according to a Haynes manual, BUT according to other threads on TGO you must hold the throttle at WOT and pull the black "wire" or tube back as hard as you can, idk how true it is, but when i just took my girlfriend home, my trans was winding out to almost 4500 before shifting to 2nd, and again to 3rd,and it was shifting hard,(and i was driving through a neighborhood at 25 mph, barely depressing the gas pedal), i guess i have to go readjust 2morrow, and hope for the best.
but if anybody would like to help, let me try and get this straight, and PLEASE CORRECT ME IF IM WRONG.
from what i understand you must
1st. push in "D" button, and push cable towards TB unit/Carb
2nd. manually go to WOT
3rd. push "D" button again, and pull the cable back as hard as you can while at WOT
is this it, or am i missing something????????
Engine: L03, LB9
Re: ADJUST YOUR TV CABLE!!!
bump....
I Need help with this one guys/gals
anybody with any info on this will help
, i really am starting to hate my haynes manual, its pretty much useless unless your using it for a tune up.
and moderator's Please move to transmission board if you need to, sorry for posting here.
, i really am starting to hate my haynes manual, its pretty much useless unless your using it for a tune up.and moderator's Please move to transmission board if you need to, sorry for posting here.
Transmission: 4L80E/4L80E
But, the "factory" way is to push in the D button and pull the housing back (away from TB) and release the button. Open the throttle to WOT, the housing will ratchet to the proper adjustment.
I've never had a problem doing it the "factory" way, and never tried the "no flex" way because it's difficult to do without another person.
Engine: L03, LB9
alright,
,i got it today went out and had a little help from the old man, got it adjusted pretty good.
88SS6SPEED
Nov 11, 2015 07:05 AM
