sort of a mystery to me...
Old Dec 25, 2007 | 12:22 PM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
first things first...MERRY CHRISTMAS! alright i have a 1992 rs camaro automatic, it was a 305 but i put a 350 in it, its still tbi. i have flowtech headers with side pipes and glass packs. with all that said, i seem to be haing a poblem with my idle...my idle will dipe and dive and eventually stall my car, especially when im lower on gas. also when i step on my breaks my rpms dive way down and then the car stalls...not too good if your trying to make a quick turn. oh and it seems that when i unplug my throttle position sensor the car runs better, otherwise my idle is so low my car barely stays running.any ideas?
Old Dec 25, 2007 | 06:24 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: sort of a mystery to me...
first,MERRY CHRISTMAS back at ya.try resetting the tps,also you can adjust the idle with the idle screw.the home page has tech articles, go to how to adjust iac & tps.ill bet the tps is out of adjustment hope this helps ,later jimmy
Old Dec 25, 2007 | 07:21 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Do you have the stock fuel pump, if so I dont think its strong enough for the 350. Just a thought hope it helps
Old Dec 26, 2007 | 01:23 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
I also think the stock 305 injectors are not sufficient for a 350, so I hope you replaced those as well and reprogrammed the prom to compensate.
Old Dec 26, 2007 | 01:49 PM
Damon's Avatar
Idle shouldn't dip when you hit the brakes. Might be a vacuum leak inside the power brake booster. Disconnect and plug that line temporarily to see if the situation improves. If it does, you found the culprit.
Agreed, the 305 injectors and chip won't run a 350 optimally without tuning but it shouldn't just die like that.
Old Dec 27, 2007 | 02:44 AM
Car: 1992 RS Camaro
let me see..305 injectors and prom...workin on getting that switched out. tps is fine...but i havent checked vacum yet. ill give it a shot.
InfernalVortex
Apr 20, 2021 11:31 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Gordonr1973
Sep 29, 2015 11:59 AM
camarohelp
Sep 12, 2015 05:45 PM
Fronzizzle
Sep 8, 2015 12:10 PM
