tpi on vortec 350
Old Dec 25, 2007 | 02:18 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
tpi on vortec 350
So i have a motor thats a vortec TBI 5.7L v8.
I have a complete tpi swap from an 86 from computer to fuel rails. Planning on buying the SDPC vortec tpi base because i think i have to, to run the tpi setup.
Now what im wondering is the 86 has the cold start injector. This vehicle will see duty all year round with temperatures up to -40 celcius, so thats probably a good thing. However when i order the vortec base from SDPC does anyone know if they have two different options for with or without the cold start injector?
If they dont have a base with the cold start injector what are my options. Just get a normal base, have to find a newer tpi fuel rail and then programm out the cold start injector from the pcm? (going to be burning chips anyways since its obd1)
Whats by best option here?
Old Dec 25, 2007 | 04:57 PM
deadtrend1's Avatar
Re: tpi on vortec 350
its been awhile since I had the runners off, but i thought bases are the same (minus the fact you need the vortec one), and the runners are where the cold start injector and non cold start are affected
Old Dec 25, 2007 | 05:03 PM
aceez71's Avatar
Car: 87 iroc camaro/2000 Z71/S-10 LB9TPI
Axle/Gears: 327
I did basically what you're planning to my S-10 All you need to do is buy a tpi 9th injector block off kit from billet works on ebay. This will have a plug for the fuel rail and a blockoff for the injector (the hole that will be left in the runner). Then all you need to do is run an 89 chip with the VATS eliminated. Then you're all set!!
Old Dec 25, 2007 | 06:08 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I used a freeze plug on a couple 9th injector holes in the runner. Cut off the pipe about 1/4" off fitting and soldered up hone, and re-installed on end of fuel rail.
They worked fine.
Old Dec 25, 2007 | 06:30 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
From what I been reading, most crate engines are tested with a carb, 330HO, 355ZZ4, 385HP, adding a TPI (stock tpi) will reduce horsepower by 30.
Old Dec 25, 2007 | 08:44 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
the tpi is a way better intake then the TBI and will make more power up to its max, im looking for torque not high end hp so 400 wheel tq shouldnt be a problem with that intake system.
thanks aceez71. Good info ill just run the blockoff on the rail and then im good to go? as far as the chip ill worry about that on the DIY board. Realistically i can just get someone to send me a stock bin thatll work and i can save it to a blank chip. Probably easiest way to go about it.
already have all the tuning stuff for my 90 SD setup
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
