3 wire 02 connector
Old Dec 23, 2007 | 01:25 PM
vetteset8087's Avatar
3 wire 02 connector
I am adding a 3 wire o2 sensor to my 87 I have the o2 it's Bosch part # 13077 it is the replacement for the GM part #. I can't find the connector for it I went to the junk yard and came home with a 4 wire plug that was all I could find. I don't want to put the 4 wire plug in if I don't have to so changing the o2 will be easier. I found 2 connectors the accel 74813 and the MSD 8172 can anybody tell me if these will work or does anybody know what cars besides the 91 ZR1 that these connectors can be taken off of?????
Old Dec 24, 2007 | 05:13 AM
Pat Hall's Avatar
Re: 3 wire 02 connector
Click on the EFI Connection sponsor link at the right side of this site and go to "other pigtails". They sell the 3 wire connector pigtail for $10, and they also sell the 3 wire conversion harness that plugs into the stock 1 wire connector for only $16.
Old Dec 24, 2007 | 12:11 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
This is the one I used for mine. A Dorman product found in the "HELP!" product line.
http://www.partsamerica.com/productd...goryCode=4074E
Old Dec 24, 2007 | 08:20 PM
Thanks for all the info I did look at the help section at schucks but did not find anything. I found it at Napa. Thanks again for all the help
Old Dec 25, 2007 | 06:10 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Where and how are you going to get ignition-source power? I have same parts to install next weekend but am unsure on where to tap into ignition-source power. Thanks, Scooter
Old Dec 25, 2007 | 06:39 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
If the fuel pump has a fuse under the hood then that would be a good spot.
Or you could run a wire out through the fire wall by the brake pedel.
Old Dec 25, 2007 | 06:49 PM
scooter500's Avatar
Car: 87 Camaro Z-28
That'd be excellent because it's so close to the O2 sensor but any suggestions on where to connect into on the fuse block or splice into another wire?
Scooter
Old Dec 25, 2007 | 08:32 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
connect to any fuse that is hot ONLY when switch is in on position ONLY. you dont want to burn the sensor up,later jimmy
Old Dec 25, 2007 | 10:28 PM
Al Hasse's Avatar
I used the pink/black ignition wire to the fuel pump relay on the firewall. Used one of the relay bracket screws as a ground. Pretty short length of twisted pair.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
