Heads?
Old Dec 29, 2007 | 01:36 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
Heads?
I might get some heads off of a TBI motor. My car is carbed with the V belt set up. Heads are off an 87 TBI, will I need to up grade to the Serp set up?
Old Dec 29, 2007 | 01:47 AM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Re: Heads?
Gonna give this a shot..
The 187 castings are not worth using, so if you are paying for them, forget it, if its from a junkyard ask for 416's. (Since you have 87 TBI heads I am assuming its the center bolt valves?) But if you get them for free, make sure you read this thread https://www.thirdgen.org/forums/tbi/...ike-these.html
from start to finish about them. I am on my 2nd.
You should not need to switch to serpentine, but I am a little fuzzy on that.
Anyone else on that? I think its mostly a preference..
Old Dec 29, 2007 | 08:25 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Heads?
The carb'd heads you have now are better. If your carb engine is 86 or older, you need a different intake manifold to run the 87 or newer heads properly..
Your old belt drive setup will bolt up fine.
Old Dec 30, 2007 | 01:58 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Heads?
if you want to pull a boat then get the tbi heads
if you want to go fast use the tbi heads for wheel chocks
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
