AMP Draw with Starter
Old Dec 31, 2007 | 08:00 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
What kind of Amperage would a starter on a 305 pull when cranking over the motor? Would it exceed 200AMPs?
I want to put in a switched fuse and need to know this to size it. 200AMP is common but might be low on the 305.
Old Dec 31, 2007 | 08:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: AMP Draw with Starter
It may spike to over 250 when it first starts to crank but while constantly cranking it should only draw about 150 to 200 amps.
You can't and have no need to fuse the starter feed wire. You'll probably blow the fuse regularly.
Old Dec 31, 2007 | 09:10 PM
Dennis-Z28's Avatar
I am going to fuse the battery. It is common practice for large stereo systems but you have to keep in mind the max AMP draw.
Old Dec 31, 2007 | 09:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Fuse the stereo system not the starter. Run a separate power wire off the battery to the fuse then from the fuse to the stereo. If your stereo draws that many amps, you'll need some battery cable to feed it.
3rd gen money
Oct 11, 2019 09:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
raymondandretti
Sep 27, 2015 06:43 PM
