will this combo break 12's?
Old Jan 8, 2008 | 01:16 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
OKay I got lower end stock 350 with a set of vortec heads, Miniram, 3.70s and a built tranny and good tires. I just need to know what cam would be good to go with this..... Help and If wit hthe right cam I could get in the 12's right?
Old Jan 8, 2008 | 01:57 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: will this combo break 12's?
i can definitely say that suspension would help considerably. that is what i am working on on my car right now.
Old Jan 8, 2008 | 03:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, you should be able to. Look at a XR276h cam, proven winner there, or even one step up. Get the computer compatible version with the longer LSA.
Tweak the valve guides so the retainers don't hit anything and you're laughing. (oh, and a 3000RPM stall speed or so).
Old Jan 9, 2008 | 12:29 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ty on the idea of a stall. I was just bout to ask that. I cant wait to get all this set up. My other question I did not adress was will 24# injectors be suffice or will I need to step up?
what about the cam? im confused now. I looked for that cam and it said it was for a 454.....
Old Jan 10, 2008 | 08:03 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
help again. lol I think I found a set of better heads than the vortecs. I also want to know if the cam I found will work with it. I want a 170-180cc head right with the miniram intake right? Also the cam should be almost a .500 lift?
BRO-1021004 one type of heads
WRL-042670-1 other heads
LUN-60103LK the cam
Im not sure on the cam but i think one of those heads will do the trick.
And they will bolt up to my dougs headers right?
Sorrry for al the nonsense questions but its my first time and I want it done right the first time.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
