Replacing Starter on '91 RS Camaro 305
Old Jan 9, 2008 | 03:16 PM
tlgrooms's Avatar
Car: '69 Camaro/'91 Camaro/'93 Camaro
Engine: 307/305/350 LT1
Transmission: Powerglide/Auto
I need to replace the starter on my '91 Camaro. I've never done this before and was wondering how difficult it is to get to, get off and replace? Will I have to remove the exhaust to get it off/on?
Thanks for any suggestions/info...
Tim
Old Jan 9, 2008 | 03:28 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Replacing Starter on '91 RS Camaro 305
All stock? Should be pretty straight forward. Disconnect the battery, jack up the car, use stands to support the vehicle. If an auto, it might help to remove the inspection cover to get the starter out. I didnt have to remove or drop the y-pipe to get the starter out. Installation is the reverse of removal. Just make sure to re-use any shims.
With replacement starter in hand, the job shouldnt take more than a couple hours if that long.
Good luck
Old Jan 9, 2008 | 03:49 PM
tlgrooms's Avatar
Yep, it's all stock. Thanks for the help!
Old Jan 9, 2008 | 04:51 PM
Joeboy's Avatar
Not a bad idea to have a friend around if you can. That starter can get heavy while youre holding it up there trying to get the bolts in. An extra set of hands allways helps.
Frozer!!!
Jan 19, 2024 04:55 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
