OK I got a knocking problem...
Old Jan 10, 2008 | 05:30 AM
86projectZ's Avatar
Car: 86 Camaro Sport Coupe
Engine: 305 V8 4bbl
Transmission: AT/overdrive
Axle/Gears: stock
Ill be honest here... I was racing and powersliding around the other night in the camaro and I think somethin bad happened...
All of a sudden I started hearing this knocking noise... kinda like when the cars low on oil, but a KNOCK instead of a light tick. It got home fine, starts and idles fine... but what the hell?
Is this a serious problem? Pushrod,valve....whats goin on here? Can I do this myself, or how much would a shop charge?
Old Jan 10, 2008 | 06:11 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: OK I got a knocking problem...
Dude if it's a rod knocking that motor is done.
Old Jan 10, 2008 | 09:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Is it still knocking?
You can grab an auto stethoscope and probe for the location of the knock while the engine is running.
I've heard intake manifold leaks sound like rod knocks before. It was on my work van, a Chevy 2500 5.7l
Old Jan 10, 2008 | 10:27 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
yeah if u spun a rod or main youll have to pull the engine and rebuild it, and turn the crank, possibly might even need a rebore. When does the knocking occur?? decelleration or accleration?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
