TPS voltage is reading backwards
Old Jan 10, 2008 | 07:18 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Alright ya know how you test the tps with a voltmeter and its .54v at idle and increases to about 4.5v at WOT?? well my buddies car is doing the exact opposite, reading 4.7 volt at idle and decreasing to .8v at WOT. Hes been having problems with a dead spot so i decided to check the tps, we switched it to two diff ones and same thing happens. could it be something wrong with the harness??
Old Jan 10, 2008 | 07:31 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: TPS voltage is reading backwards
do you have the volt meter leads in terminals a and b? never seen 1 do this,later jimmy
Old Jan 10, 2008 | 08:23 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yep, i havent either, i cant explain it other than the harness being messed up somehow?? either that or we have 3 really messed up tps's but what are the chances of that
Old Jan 10, 2008 | 09:12 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
look i just googled it ,they say to run a ground wire from throttle body to a ground and reset it and it will read correctly .you can go to www.google.com put in tps reading backwards,it will pull it up go in first or second article ,later jimmy
Old Jan 10, 2008 | 10:38 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yeah im not fully understanding what that guy was trying to say. I also read that i should try switching the wires. How the hell could they got reversed in the first place is a mystery, ill do that tommorow morning and see what happens.
Old Jan 11, 2008 | 08:06 AM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
i have a 91 transam,305 tpi.my wiring is;black (top) blue (middle) white(bottom)on my tps.i hope you get it fixed,later jimmy
Hotrodboba400
Dec 10, 2019 07:07 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
andy74
Sep 3, 2015 08:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
RyanJB
Sep 2, 2015 01:27 PM
