Tank Pressure Control Valve
Old Jan 14, 2008 | 01:27 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
I tried this in the TPI section since my engine is TPI, maybe I'll have better luck here.
Tank Pressure Control valve.....
Does anyone have a part number, picture or a place to buy one.
It mounts between the charcoal canister and fuel tank vent line..
1990 - 1992 5.7 TPI if that helps
Thanks!!
Old Jan 14, 2008 | 02:21 PM
Car: 1971 Camaro
Re: Tank Pressure Control Valve
Is this what I'm looking for?? Could someone look at thiers and see if this is it?
Old Jan 26, 2008 | 12:59 AM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
No that is a canister control valve, Autozone calls it a canister purge valve, either way it goes on carb. applications.
Old Jan 26, 2008 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dime a dozen at the JY's. If it's the fuel tank evaporator control, it's p/n 17087240, a good p/n on GMPartsDirect. You might ask at your dealership.
JamesC
backtothe80s
Sep 5, 2015 12:39 AM
BurlyChev
Aug 16, 2015 09:08 PM
Kaweh
Aug 9, 2015 02:54 PM
