Car broke down!
Old Jan 15, 2008 | 03:06 PM
cpiper89's Avatar
Car broke down!
I was driving to college today and my car started to rock back and forth when it would shift... almost like it would cut in and out. Later on my way back from college the car would not accelerate over 45-50 and it was getting hotter by the minute, it was also being extremely loud (almost as if it was reved up all the way, even though it wasn't) so i decided that i would pull over and let it cool down and try to start it again her in a little bit. Well the car started fine but as soon as i put it into drive and would slowly accelerate (probably get going 3-4 mph) and then it would die and the whole engine would cut off. I started it up again but it kept doing the same thing. Does anybody know what is wrong with my car --> 1990 Camaro I-ROC Z.
Old Jan 15, 2008 | 06:19 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Car broke down!
ignition modules go frequently on these cars
Old Jan 15, 2008 | 07:29 PM
cpiper89's Avatar
Re: Car broke down!
well i did just change the spark plugs on it... do you think that we me messing with the plugs it could of effected the ignition module,, is the ignition module cheap and easy to replace
Old Jan 15, 2008 | 08:54 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Re: Car broke down!
first verify that your getting spark
if you are, but the car dies after getting hot, check spark then.
If u do have it, look else where
If u dont have it, Most likely in this case its the ignition module, it is the little plastic module under the dist. cap held on by 2 screws and has 2 connectors u can get them tested at most auto parts stores. there aprox 50-60$ to replace
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
