tie rod end
Old Jan 16, 2008 | 11:51 AM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
tie rod end
I replaced the center link in my camaro but the tapers on the inner tie rod end are spinning freely, my chilton book says to set them to 15ft/lbs, but does not say how. does anyone know how to get them torqued down?
Old Jan 16, 2008 | 12:24 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Re: tie rod end
Find a way to put some pressure on it, forcing the cone into the taper. If the grease fitting is in the way, carefully remove it, and put it back in when it it does tighten up.
Old Jan 16, 2008 | 08:40 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: tie rod end
Put a jack under it to put some pressure on it.
Old Jan 16, 2008 | 08:44 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: tie rod end
I just used a pair of channel loks to squeeze the two pieces together....
Old Jan 17, 2008 | 01:35 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: tie rod end
I'm confused, the cone shaped part is spinning freely inside the tapered hole? Did you not tighten the nut all the way and install the cotter pin?
Old Jan 17, 2008 | 05:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: tie rod end
Start the nut, then stick a pry bar between the center and end link. Put pressure on the pry bar (and thus the nut) until you can draw the 'cone-shaped" piece into place. Once it's there, of course, it won't spin and you can tighten to spec.
JamesC
Ghettobird52
Apr 21, 2020 08:44 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
