ETHANOL-E10 and my 1983 Camaro Sport Coupe
Old Jan 16, 2008 | 03:50 PM
GeneL's Avatar
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
Hi all,
Oregon state law, beginning yesterday Jan 15, now requires all gasoline retailers in Oregon to pump fuel with 10 percent Ethanol, or E10.
I'm hearing different cautions regarding this biofuel mix, expecially that it could potentially be harmful to "older" cars....
for example: Decreased mileage-Decreased spark plug life (due to pre-ignition) Rubber and Plastic compontents in older cars may not be compatable with alcohol. (fuel lines, diaphrams, coated needles and seats, o-rings...etc) may need replacement.
Many floats will absorb alcohol making them too heavy to float.
I have a 1983 Camaro (5-Liter, V8, 305, 5-Speed).
(I've ALWAYS used Premium of course-typically I've used Arco and for the past six years Chevron)
This has me greatly concerned since I've never had any engine problems with this car.
Since I now have NO CHOICE, what affect can I expect this biofuel to have on this car...good and adverse?
Old Jan 16, 2008 | 04:19 PM
Re: ETHANOL-E10 and my 1983 Camaro Sport Coupe
None....
"Gasohol" has been around for years. Works fine. Expect your mileage to go down a bit, that's about the only difference you'll notice.
Your car will produce more power and use less fuel if you use regular. Regular fuel actually contains more energy tha premium; the only benefit to premium is resistance to "pinging" in higher compression engines... which these aren't. Beyond that, it's a marketing gimmick to pry the uninformed away from EVEN MORE of their cash.
Old Jan 16, 2008 | 05:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, winter gas is usually 10% ethanol. There's a microscopic difference in mileage, other then that you'd never know it.
Old Jan 16, 2008 | 05:49 PM
GeneL's Avatar
Thanks guys, your replies are certainly reassuring.
Gasohol may have been "around for years" but (as far as I know) this will be the first time I'll be introducing it into my fuel system.
"Your car will produce more power and use less fuel if you use regular."
I'd like nothing more than to switch to Regular just to be able to offset the rising gas prices...
BUT, I'm gonna really need to think about that one. I'll take under consideration your recommendation sofakingdom but (with all due respect) will check around these forums for "second opinions" on the subject (point me the way to pertinent threads if you like).
Thanks again, more posts on the subject welcome.
Old Jan 16, 2008 | 05:56 PM
Nsomnia's Avatar
Octane (premium is 91/93 and regular is 87) is the fuels ability to resist detonation.
Lower octane means the gas burns easier and at lower compressions.
If it doesnt knock, run regular.
Old Jan 16, 2008 | 06:03 PM
Screw the forums. Your car doesn't read forums.
Put regular in your car. If it doesn't ping, you don't need premium. It's a double waste of money (extra price, and worse mileage), and the oil companies' marketing plan to get more of your money has been working as intended. That's all you need to know.
Old Jan 16, 2008 | 06:08 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
lower octane gas is said to burn cleaner as well, i.e. less emisions, which also means cleaner and easier burning fuel. 91/93 is great...but why not just throw a $1 of octane booster in there to your entire tank instead of paying $.50-$1 more a gallon?? Just a thought, but that is why regular motors unless you drive a mercedes benz suggest hum drum 87, while turbo/supercharged motors with the higher compression need the 91+ for the pinging issue. Completely up to you, but gas is gas, and your car will not implode if you switched back to 87. just my from the research i've done on my own.
Cleotiz
Jan 6, 2018 08:56 PM
gta90
Sep 15, 2015 04:00 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Dan's 83z28
Exterior Parts Wanted
Aug 20, 2015 02:16 AM
