1988 TPI IROC 305
Old Jan 17, 2008 | 11:38 PM
OuTKa5t's Avatar
1988 TPI IROC 305
I know this topic has been covered about a million times over, but somewhere along the way all the info has become scattered about and muttled so much that it is impossible to figure out the "correct" answer.
I have the above mentioned vehicle. I have no intention of switching up to a 350...so please dont give me that advice.
I have 1000 bucks right now.
I would like to get 300+ HP out of the engine.
How can i do it? Where can I get the parts? How far will my grand get me?
on a side note i have a 98 grand prix everyday driver....i have been looking into dashboard swaps for third gens and was wondering if a 98 grand prix dash would fit into my 88 iroc. Just a thought, otherwise im about to junk it, scrap it out, or sell it off for next to nothing.
Thanks....
Old Jan 18, 2008 | 12:35 AM
Montage's Avatar
Re: 1988 TPI IROC 305
if you do a lot of smart shopping a grand can get you pretty far..
you tryin to do bolt ons or motor work?
and no the dash wont fit
Old Jan 18, 2008 | 04:47 AM
Dirk Edgewoode's Avatar
I'm interested in seeing where this thread goes as well.. Friend on a tight budget has a LG4 V8 (yes, I know. Don't have to say how bad it is) and is wanting to get some extra HP out of it. It's not fesable to go to a 350 yet for him, so he's trying to stretch the most out of his 4bbl 305 for the time being. Any ideas?
Old Jan 18, 2008 | 09:13 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
go with 601, 416, 081 or the newer vortec 305 casting heads. Port them.
i'd say your talking 100$ for a set if that.
a roller cam along the lines of a lt1 camshaft thats another 50$
or if you want to go aftermarket so it's a little nastier used wil run you 100-200$
100$ for gaskets.
300$ for head machine work.
thats 750 currently....
if you have a efi engine don't forget the price of an upgraded set of injectors, an easy 100$, if tpi you will want to mod the **** out of it or go to an aftermarket stealth ram or such s.r.= 500$, modded tpi =free but, much less power.
either way ported above heads with full machining done and a good camshaft will get you near 300hp on a 305 with perfect tuning be it carb'd or efi.
then of course you have the dreaded exhaust thats between 400$ and 1000$ to get it out the rear.......
basically if you go used and shop around a set of headers and used catback will run maybe 200$ if you have tpi and plan to mod yourself by porting thats free, injectors = another 100$,
basically at cheapest you'd be around 1050 for a efi setup i'd say.
i bought a 2032 crane cam for my 305 and had 416 heads in the shed, that i ported so basically i plan to siamese the base and blend the plenum and leave it alone.
i'll have 125$ in my cam, 300$ in machining, but, i already have 22# injectors and edelbrock headers and borla catback so basically i will be a 700$ upgrade or so 4 me.
Old Jan 18, 2008 | 08:58 PM
OuTKa5t's Avatar
Rather do bolt ons....however i have access to a full mechanical shop to do some work if needs be....however, past changing out alternators, water pumps, and pullys i am not that familliar with engine work.
Thanks for the info on the dash!
Old Jan 19, 2008 | 08:50 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Headers and free flowing exhaust.
Free mods: Port the plenum, etc. Do a search, and you will find many.
Adjustable fuel pressure regulator.
Heads, and cam, as mentioned above. It is challenging, but, not impossible for a neophyte to do this. Get a GOOD manual, and draft someone that has done it before, and you should be good to go.
Old Jan 19, 2008 | 10:14 AM
OuTKa5t's Avatar
Ok....So...
what heads do you reccomend?
cam?
exhaust?
should i buy these from jegs or summit or is there somewhere i can go to get them used/cheaper?
thnx..
Old Jan 21, 2008 | 03:00 PM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
The easiest way to get that kind of power in a 305 at the rear wheels is headers and a 175 wet kit of nitrous.
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
