oil passage / coolant passage .. do i need to plug this hole???
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i just rebuilt my 305 tpi in my 1991 camaro z28 and there is a bolt hole on the driver side of the block above the freeze plug just infront of the oil filter / oil pressure sender ..
do i need to plug this hole (if so ..with what?) .. or is it for something that i dont have ..
thanks,
adrian
thanks,
adrian
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: oil passage / coolant passage .. do i need to plug this hole???
Is it a blind hole or does it go into a gallery?
A blind hole would be for mechanical clutch linkage. If it goes into a gallery, it will need to be plugged. Probably a 1/4" pipe plug.
Transmission: 5 spd
i dont know .. i just got the motor back in the car and its just above a freeze plug , and its about an inch or so deep ..
the machine shop didnt plug it .. i got some 1/4" plugs and they dont fit .. its a little smaller ..
i got a hydraulic clutch assembly ..
im going to fill it with coolant and oil tommorow .. so i guess i'll find out ..
its about 6" in front of the oil pressure sender ..
i tried poking a zip tie around in the hole but coudnt tell if it was a passage for anything .. would it be easy to tell ? ..
adrian
adrian
Car: 87 IROC L98
yes.
Pipe plugs are a tapered thread. If a pipe plug doesn't fit then it's not a pipe plug thread. Mechanical clutch linkage uses regular threaded bolts although I can't say if your block will be NC, NF or metric threads. I doubt it's a 1/8 pipe fitting.
Yes your car has a hydraulic clutch but that block casting is used on more than just f-bodies.
Above a freeze plug won't be a coolant gallery unless it's for a knock sensor but the knock sensor is usually on the other side of the block. Coolant drains are below the freeze plugs. Oil galleries are just above the pan rail or right around the filter housing.
Transmission: 5 spd
ok .. then it must just be a bolt hole ..
thanks for your help ..
hopefully im gonna get it runnin later today ..
just crossin my fingers that the damn thing doesnt blow up .. lol ..
adrian
adrian
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
