LO3 engines ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
LO3 engines ???
well i have searched , but i still don't understand why not many specs. on lo3 cylinder heads ? i am just curious , i am not going to change anything . i'm a cruiser not a racer , and a hwy. traveler ( 27-29 m.p.g. ) . so i like the m.p.g. . did g.m. just throw heads out there , and say here you are ?? oh yes , 89rs , van nuys , 305 t.b.i. , t-5 , 3.08 . anyway just general info. , thanks in advance .
Re: LO3 engines ???
They're nothing to write home about. ~58cc chambers, 1.84/1.50 valves, 87-up intake bolt pattern. The main thing to know about them is that they are "swirl port" heads where the intake port is very odd looking- about half of it is blocked off and the area under the intake valve is one big swirly "ski jump" in an early attempt to induce swirl to the mixture. As you can imagine, this was not so great for intake flow (power), although it helped emissions and economy. Various members have flowed these heads and typical numbers are 165 intake, 140 exhaust.
Transmission: 4L80E/4L80E
Car: 1983 G20 Chevy
Transmission: 4L60
84z96L31vortec
Aug 20, 2017 12:16 AM
