Stock Valve springs or?
Old Jan 26, 2008 | 11:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi
Found some springs in a abox in my garage, and I cant remember if its the stock ones or the TPIS 700-132 I bought in -98?
Anyone have any dimensions or pictures of stock valve springs frpm a 350TPI -89 ?
Spings I have are double.
OD 1.25"
ID 0.8" inner spring
Height no load 2"
Old Jan 26, 2008 | 12:18 PM
Damon's Avatar
Re: Stock Valve springs or?
Can't tell much just by looking at them- there are too many differences that can't be seen by eye. I use a spring tester when it doubt. Take them to a local machine shop and have them do a quick check for you. At 1.70" a stock spring will be about 70 lbs. A typical performance oriented spring of the same diameter will be more like ~100 lbs.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
