Trick Flow Top End Kit
Subscribe
Feb 1, 2008 | 01:33 PM
Anyone use this setup. Have built a 383 stroker shortblock with all the goodies. Looking for a cam/head combo.Any ideas,comments,or suggestions welcome.Please keep it civil and based on experiance. http://www.trickflow.com/egnsearch.a...2&autoview=sku
Reply 0
Feb 2, 2008 | 12:51 PM
Re: Trick Flow Top End Kit
what pistons do you have and rod length, also is it going to be all motor or spray, forced?
Reply 0
Feb 2, 2008 | 01:12 PM
I hope you have a Roller Block already or you can add the price to convert it, i have the 425 flat tappet version of that on my 89 it seems to do ok....
Reply 0
Feb 2, 2008 | 02:28 PM
Flat top +5.00cc valve reliefs forged pistons, 6" h-beam rods,no NOS,just motor and using retro hyd.Roller lifters,single 4-barrel carb and intake.
Reply 0
Feb 2, 2008 | 04:24 PM
i have read that older trickflow heads have had alot of problems such as their old twisted wedge line:
https://www.thirdgen.org/forums/afte...+twisted+wedge
i have heard that the problem is easy to fix and i have also heard that it has been corrected since then, but i think those issues probably scared alot of sbc guys away from trick flow. i havent seen too many people with them in their signatures either.
i come from the mustang world where trickflow has a great reputation and i initailly looked at those heads for my 350 (that exact kit) but i have since looked toward other brands with relatively unscarred reputations.
do some more searching, there is tons of info out there.
Reply 0
Feb 2, 2008 | 08:39 PM
From what I understand from reading that thread, the problem related to incorrect valvetrain geometry, and not from any design flaw in the heads. If you go by the manufacturers recommendations for rocker arms, and pushrod length, should be golden.
Reply 0
Feb 3, 2008 | 10:16 AM
Quote: From what I understand from reading that thread, the problem related to incorrect valvetrain geometry, and not from any design flaw in the heads. If you go by the manufacturers recommendations for rocker arms, and pushrod length, should be golden.
Recommendations on pushrod length are pretty much worthless. An engine needs the length that it needs. Too many variables exist not to measure for proper length.
Reply 0
Subscribe
