oil pump stud
Old Feb 5, 2008 | 11:45 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
oil pump stud
I have a new in the wrapper arp oil pump stud.
Do I need it?
Is the stock bolt adequate?
How do I install the stud?
Hand tight: and then torque the nut to 65 ft lbs?
Also related...
How much travel do I need in the oil pump drive shaft with the dist installed. I do not want it to bind, but I don't want it to disconnect either.
I have a dist with a collar and can adjust the depth.
Old Feb 6, 2008 | 06:47 AM
Re: oil pump stud
Note that the hole in the main cap for that bolt, goes ALL THE WAY THROUGH, to the back of the bearing. If you put the stud in too far or use too long of a bolt, it will press on the back of the bearing insert and cause a failure.
Yes, something in the 55-65 range would be appropriate for that nut, like most any 7/16" hardware, since torque goes with hardware size. As always, the engineers who designed the system chose a size of hardware adequate to give the required clamping force when torqued to its "nominal" kind of torque. Had they needed more or less clamping force, they would have chosen a different size fastener, which would then also have brought its own "nominal" torque value with it.
Old Feb 6, 2008 | 09:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: oil pump stud
The stud has an allen drive on the top right? IIRC you tighten it until the threads bottom out. I'd use red loctite as well, and just snug it into the bearing cap, 20 ftlbs maybe. Let that setup. Then install the oil pump and torque the nut to 65ft lbs as mentioned.
Adjustable depth? huh, no idea on that one.
Old Feb 6, 2008 | 09:59 AM
Re: oil pump stud
No; that's just it. You DO NOT do that.
The stud will "bottom out" ON THE BACK OF THE MAIN BEARING. Very very very very very bad. And not good, either.
Old Feb 6, 2008 | 10:14 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: oil pump stud
Ok! Fair enough then.
With other studs, head studs, main caps etc, is that what you'd do? Tighten until the end of the stud threads hit the surface?
So i'd guess you'd want to remove the #5 cap and put the stud in and watch how far in it's going? I would have thought the stud should be the right length such that it'd bottom out on the threads before the end of the threads hit the main bearing.... Seems like a bit of a design flaw eh?
Old Feb 6, 2008 | 10:27 AM
Re: oil pump stud
Yup, with other studs, that's about it.
I'm not sure if the ARP oil pump one is made the same way. It'd be something you'd definitely want to check with the main cap off the motor, BEFORE porking the pooch, though.
You'll also note that the main cap has different thicknesses for the 3 journal sizes of small blocks; and that the surface in the cap that the stud WOULD bottom against, is left "as-cast", a little bowl in fact, NOT machined flat. So it has LOTS of tolerance. There's clearly ALOT of ways that "bottoming" that stud could create problems.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
