intake bolts
Old Feb 6, 2008 | 12:59 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
intake bolts
i searched and couldnt find anything. I wasn't thinking when i removed the intake bolts so i just put them all in a ziplock bag. can anyone tell me where the bolts go back in the intake because there are two different sizes.
Last edited by blackandgoldl69; Feb 6, 2008 at 01:00 PM. Reason: Automerged Doublepost
Old Feb 6, 2008 | 01:21 PM
Engine: L69 H.O
Re: intake bolts
Please help i was really hoping to get it back on Today
Old Feb 6, 2008 | 01:33 PM
Re: intake bolts
You should have, at most, 2 different sizes; 3 long (should be washer head for sure), 9 short (might or might not have washer heads).
2 long ones go at the left front, and hold on a bracket. The other long one goes at the right rear and also holds a bracket. All the others are short. A coupld of them hold the throttle cable bracket; use washer head ones there.
Old Feb 6, 2008 | 02:06 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: intake bolts
when i did my swap i did a write up/hand drawn diagram of where all the brackets go and the different sizes and diff types of bolts/studs...i can post it tonight when i get back home from college.
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
